[GRASS-QA] GRASS QA: cho | ./grass6/lib/driver/Get_location.c |no
clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 22:56:31 EDT 2006
Hello cho,
ANALYSIS
lib/driver/Get_location.c functions
COM_Get_location_with_pointer (Begins at: 4 Ends at: 16)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 13 | | OK |
metrics are OK
COM_Get_location_with_line (Begins at: 18 Ends at: 30)
ParamNBR: | 6 | * | |
LOC: | 13 | | OK |
metrics are OK
COM_Get_location_with_box (Begins at: 32 Ends at: 44)
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
