[GRASS-QA] GRASS QA: cho | ./grass6/lib/driver/init.c |1 clones ( edit.c init.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 22:56:32 EDT 2006
Hello cho,
ANALYSIS
lib/driver/init.c functions
LIB_init (Begins at: 29 Ends at: 72)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  LIB_init
In lib/driver/init.c clones of  LIB_init are:
	display/drivers/lib/init.c  LIB_init
Threshold GRASS6 key metrics values at 2006-06-28 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
