[GRASS-QA] GRASS QA: cho | ./grass6/vector/v.digit/attr.c |no
clones | 0 monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 22:56:32 EDT 2006
Hello cho,
ANALYSIS
vector/v.digit/attr.c functions
del_cat (Begins at: 18 Ends at: 49)
Complexity: | 3 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 32 | | OK |
metrics are OK
add_cat (Begins at: 51 Ends at: 92)
Complexity: | 7 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 42 | | OK |
metrics are OK
new_record (Begins at: 100 Ends at: 155)
Complexity: | 6 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 21 | | OK |
LOC: | 56 | | OK |
metrics are OK
display_cats (Begins at: 159 Ends at: 243)
ParamNBR: | 1 | | OK |
CalledNBR: | 37 | * | |
LOC: | 85 | | OK |
metrics are OK
copy_cats (Begins at: 246 Ends at: 368)
Complexity: | 19 | * | |
CalledNBR: | 47 | * | |
LOC: | 123 | * | |
metrics are OK
display_attributes (Begins at: 371 Ends at: 497)
Complexity: | 10 | | OK |
CalledNBR: | 64 | ** | Warning |
LOC: | 127 | * | |
at least 1 values are close to an outlier please consider revising code
check_record (Begins at: 504 Ends at: 570)
Complexity: | 9 | | OK |
CalledNBR: | 27 | | OK |
LOC: | 67 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
