[GRASS-QA] GRASS QA: cho | ./grass6/vector/v.digit/zoom.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 22:56:32 EDT 2006
Hello cho,
ANALYSIS
vector/v.digit/zoom.c functions
zoom_window (Begins at: 12 Ends at: 82)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      25 |       |      OK |
LOC:          |      71 |       |      OK |
metrics are OK
zoom_centre (Begins at: 85 Ends at: 122)
Complexity:   |       1 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
zoom_pan (Begins at: 125 Ends at: 177)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      53 |       |      OK |
metrics are OK
zoom_default (Begins at: 180 Ends at: 200)
CalledNBR:    |       9 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
zoom_region (Begins at: 203 Ends at: 229)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-28 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
