[GRASS-QA] GRASS QA: cho | ./grass6/lib/driver/Get_location.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 23:03:04 EDT 2006
Hello cho,
ANALYSIS
lib/driver/Get_location.c functions
COM_Get_location_with_pointer (Begins at: 4 Ends at: 16)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
COM_Get_location_with_line (Begins at: 18 Ends at: 30)
ParamNBR:     |       6 |     * |         |
LOC:          |      13 |       |      OK |
metrics are OK
COM_Get_location_with_box (Begins at: 32 Ends at: 44)
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-28 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
