[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.info/main.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Thu Jun 29 09:10:33 EDT 2006
Hello hamish,
ANALYSIS
display/d.info/main.c functions
main (Begins at: 22 Ends at: 124)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      52 |     * |         |
LOC:          |     103 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-29 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
