[GRASS-QA] SOCCER LAB GRASS QA: no clones 2 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue May 2 03:34:46 EDT 2006
Hello hamish,
ANALYSIS
display/d.rast.num/number.c functions
main (Begins at: 53 Ends at: 310)
Complexity: | 21 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 91 | *** | MONSTER |
LOC: | 258 | *** | MONSTER |
2 metric are OUT OF RANGE!
draw_number (Begins at: 314 Ends at: 362)
Complexity: | 5 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 49 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-05-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 256 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
