[GRASS-QA] SOCCER LAB GRASS QA: no clones 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue May 2 03:34:46 EDT 2006
Hello hamish,
ANALYSIS
vector/v.label/main.c functions
main (Begins at: 34 Ends at: 387)
Complexity:   |      36 |   *** | MONSTER |
CalledNBR:    |     119 |   *** | MONSTER |
LOC:          |     354 |   *** | MONSTER |
3 metric are OUT OF RANGE!
print_label (Begins at: 389 Ends at: 411)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      17 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-02 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
