[GRASS-QA] SOCCER LAB GRASS QA: no clones 1 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue May 2 09:29:50 EDT 2006
Hello radim,
ANALYSIS
lib/form/form.c functions
close_form (Begins at: 37 Ends at: 42)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
reset_values (Begins at: 46 Ends at: 55)
CalledNBR: | 0 | | OK |
LOC: | 10 | | OK |
metrics are OK
set_value (Begins at: 58 Ends at: 81)
Complexity: | 6 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 24 | | OK |
metrics are OK
submit (Begins at: 85 Ends at: 250)
Complexity: | 17 | * | |
CalledNBR: | 90 | *** | MONSTER |
LOC: | 166 | * | |
1 metric are OUT OF RANGE!
main (Begins at: 256 Ends at: 389)
Complexity: | 15 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 72 | ** | Warning |
LOC: | 134 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-05-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 256 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
