[GRASS-QA] SOCCER LAB GRASS QA: 4 clones ( gs_bm.c ) 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue May 2 15:31:34 EDT 2006
Hello brad,
ANALYSIS
lib/ogsf/gs_bm.c functions
gsbm_make_mask (Begins at: 16 Ends at: 52)
Complexity: | 4 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 37 | | OK |
metrics are OK
gsbm_zero_mask (Begins at: 54 Ends at: 74)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 21 | | OK |
metrics are OK
gsbm_masks (Begins at: 76 Ends at: 118)
Complexity: | 9 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 43 | | OK |
metrics are OK
gsbm_or_masks (Begins at: 121 Ends at: 124)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 4 | | OK |
metrics are OK
gsbm_ornot_masks (Begins at: 127 Ends at: 130)
LOC: | 4 | | OK |
metrics are OK
gsbm_and_masks (Begins at: 133 Ends at: 136)
LOC: | 4 | | OK |
metrics are OK
gsbm_xor_masks (Begins at: 139 Ends at: 142)
LOC: | 4 | | OK |
metrics are OK
gs_update_curmask (Begins at: 145 Ends at: 267)
Complexity: | 17 | * | |
CalledNBR: | 29 | | OK |
LOC: | 123 | * | |
metrics are OK
print_bm (Begins at: 270 Ends at: 283)
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
gsbm_xor_masks gsbm_and_masks gsbm_ornot_masks gsbm_or_masks
In lib/ogsf/gs_bm.c clones of gsbm_xor_masks are:
lib/ogsf/gs_bm.c gsbm_and_masks
In lib/ogsf/gs_bm.c clones of gsbm_or_masks are:
lib/ogsf/gs_bm.c gsbm_ornot_masks
In lib/ogsf/gs_bm.c clones of gsbm_ornot_masks are:
lib/ogsf/gs_bm.c gsbm_or_masks
In lib/ogsf/gs_bm.c clones of gsbm_and_masks are:
lib/ogsf/gs_bm.c gsbm_xor_masks
Threshold GRASS6 key metrics values at 2006-05-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 256 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
