[GRASS-QA] SOCCER LAB GRASS QA: 1 clones ( main.c ) 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed May 3 04:33:02 EDT 2006
Hello hamish,
ANALYSIS
display/d.mon/cmd/main.c functions
main (Begins at: 16 Ends at: 135)
Complexity:   |      16 |     * |         |
CalledNBR:    |      42 |     * |         |
LOC:          |     120 |     * |         |
metrics are OK
run (Begins at: 137 Ends at: 143)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  run
In display/d.mon/cmd/main.c clones of  run are:
	raster/r.what/die.c  die
	raster/r.digit/create_map.c  create_map
Threshold GRASS6 key metrics values at 2006-05-03 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
