[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
    cvs at proxy.soccerlab.polymtl.ca
    Wed May  3 04:47:32 EDT 2006
Hello hamish,
ANALYSIS
display/d.rgb/main.c functions
main (Begins at: 19 Ends at: 134)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      44 |     * |         |
LOC:          |     116 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-03 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
