[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed May 3 23:33:27 EDT 2006
Hello hamish,
ANALYSIS
lib/gis/range.c functions
G__remove_fp_range (Begins at: 93 Ends at: 111)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 19 | | OK |
metrics are OK
G_construct_default_range (Begins at: 113 Ends at: 138)
LOC: | 26 | | OK |
metrics are OK
G_read_fp_range (Begins at: 140 Ends at: 238)
Complexity: | 10 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 22 | | OK |
LOC: | 99 | | OK |
metrics are OK
G_read_range (Begins at: 240 Ends at: 348)
Complexity: | 14 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 109 | | OK |
metrics are OK
G_write_range (Begins at: 350 Ends at: 397)
Complexity: | 4 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 48 | | OK |
metrics are OK
G_write_fp_range (Begins at: 399 Ends at: 451)
Complexity: | 5 | | OK |
LOC: | 53 | | OK |
metrics are OK
G_update_range (Begins at: 453 Ends at: 471)
CalledNBR: | 1 | | OK |
LOC: | 19 | | OK |
metrics are OK
G_update_fp_range (Begins at: 475 Ends at: 508)
LOC: | 34 | | OK |
metrics are OK
G_row_update_range (Begins at: 510 Ends at: 515)
LOC: | 6 | | OK |
metrics are OK
G__row_update_range (Begins at: 519 Ends at: 545)
Complexity: | 6 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 27 | | OK |
metrics are OK
G_row_update_fp_range (Begins at: 549 Ends at: 601)
CalledNBR: | 5 | | OK |
LOC: | 53 | | OK |
metrics are OK
G_init_range (Begins at: 603 Ends at: 630)
LOC: | 28 | | OK |
metrics are OK
G_get_range_min_max (Begins at: 632 Ends at: 668)
CalledNBR: | 6 | | OK |
LOC: | 37 | | OK |
metrics are OK
G_init_fp_range (Begins at: 670 Ends at: 693)
LOC: | 24 | | OK |
metrics are OK
G_get_fp_range_min_max (Begins at: 695 Ends at: 718)
LOC: | 24 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-05-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 256 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
