[GRASS-QA] SOCCER LAB GRASS QA: no clones 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Thu May 4 03:33:37 EDT 2006
Hello hamish,
ANALYSIS
raster/r.info/main.c functions
main (Begins at: 35 Ends at: 442)
Complexity:   |      57 |   *** | MONSTER |
CalledNBR:    |     197 |   *** | MONSTER |
LOC:          |     408 |   *** | MONSTER |
3 metric are OUT OF RANGE!
format_double (Begins at: 445 Ends at: 451)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-04 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     255 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
