[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Thu May 4 15:45:20 EDT 2006
Hello cedric,
ANALYSIS
vector/v.digit/main.c functions
Tcl_AppInit (Begins at: 25 Ends at: 87)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      29 |       |      OK |
LOC:          |      63 |       |      OK |
metrics are OK
main (Begins at: 89 Ends at: 207)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      56 |    ** | Warning |
LOC:          |     119 |     * |         |
at least 1 values are close to an outlier please consider revising code
end (Begins at: 210 Ends at: 218)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-04 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     255 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
