[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Thu May 4 15:45:20 EDT 2006
Hello cedric,
ANALYSIS
vector/v.digit/c_face.c functions
c_cancel (Begins at: 20 Ends at: 26)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
c_next_tool (Begins at: 30 Ends at: 96)
Complexity:   |      24 |     * |         |
CalledNBR:    |      27 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
c_set_color (Begins at: 100 Ends at: 125)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
c_set_on (Begins at: 129 Ends at: 151)
CalledNBR:    |       7 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
c_tool_centre (Begins at: 154 Ends at: 160)
LOC:          |       7 |       |      OK |
metrics are OK
c_table_definition (Begins at: 164 Ends at: 214)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      25 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
c_create_table (Begins at: 218 Ends at: 311)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      72 |    ** | Warning |
LOC:          |      94 |       |      OK |
at least 1 values are close to an outlier please consider revising code
c_var_set (Begins at: 315 Ends at: 343)
LOC:          |      29 |       |      OK |
metrics are OK
c_create_bgcmd (Begins at: 347 Ends at: 358)
LOC:          |      12 |       |      OK |
metrics are OK
c_set_bgcmd (Begins at: 362 Ends at: 383)
Complexity:   |       2 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
c_add_blank_bgcmd (Begins at: 387 Ends at: 402)
CalledNBR:    |       6 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
c_del_cat (Begins at: 406 Ends at: 426)
LOC:          |      21 |       |      OK |
metrics are OK
c_add_cat (Begins at: 430 Ends at: 456)
CalledNBR:    |       8 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-04 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     255 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
