[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 2 warnings
cvs at proxy.soccerlab.polymtl.ca
Fri May 5 19:38:31 EDT 2006
Hello brad,
ANALYSIS
lib/ogsf/gsd_objs.c functions
init_stuff (Begins at: 92 Ends at: 129)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 38 | | OK |
metrics are OK
gsd_plus (Begins at: 131 Ends at: 157)
Complexity: | 1 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 27 | | OK |
metrics are OK
gsd_line_onsurf (Begins at: 160 Ends at: 186)
CalledNBR: | 4 | | OK |
LOC: | 27 | | OK |
metrics are OK
gsd_nline_onsurf (Begins at: 193 Ends at: 224)
ParamNBR: | 5 | * | |
LOC: | 32 | | OK |
metrics are OK
gsd_x (Begins at: 227 Ends at: 267)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 41 | | OK |
metrics are OK
gsd_diamond (Begins at: 269 Ends at: 360)
CalledNBR: | 47 | * | |
LOC: | 92 | | OK |
metrics are OK
gsd_cube (Begins at: 362 Ends at: 428)
CalledNBR: | 43 | * | |
LOC: | 67 | | OK |
metrics are OK
gsd_draw_box (Begins at: 430 Ends at: 480)
CalledNBR: | 35 | * | |
LOC: | 51 | | OK |
metrics are OK
gsd_drawsphere (Begins at: 481 Ends at: 488)
CalledNBR: | 2 | | OK |
LOC: | 8 | | OK |
metrics are OK
gsd_diamond_lines (Begins at: 490 Ends at: 508)
CalledNBR: | 12 | | OK |
LOC: | 19 | | OK |
metrics are OK
gsd_draw_asterisk (Begins at: 510 Ends at: 556)
CalledNBR: | 30 | | OK |
LOC: | 47 | | OK |
metrics are OK
gsd_draw_gyro (Begins at: 558 Ends at: 603)
CalledNBR: | 26 | | OK |
LOC: | 46 | | OK |
metrics are OK
gsd_3dcursor (Begins at: 605 Ends at: 639)
LOC: | 35 | | OK |
metrics are OK
dir_to_slope_aspect (Begins at: 641 Ends at: 697)
Complexity: | 8 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 57 | | OK |
metrics are OK
gsd_north_arrow (Begins at: 703 Ends at: 781)
CalledNBR: | 32 | | OK |
LOC: | 79 | | OK |
metrics are OK
gsd_arrow (Begins at: 783 Ends at: 842)
ParamNBR: | 6 | * | |
CalledNBR: | 22 | | OK |
LOC: | 60 | | OK |
at least 1 values are close to an outlier please consider revising code
gsd_arrow_onsurf (Begins at: 845 Ends at: 928)
LOC: | 84 | | OK |
metrics are OK
gsd_3darrow (Begins at: 933 Ends at: 1003)
CalledNBR: | 27 | | OK |
LOC: | 71 | | OK |
primitive_cone (Begins at: 1007 Ends at: 1034)
CalledNBR: | 13 | | OK |
LOC: | 28 | | OK |
metrics are OK
primitive_cylinder (Begins at: 1038 Ends at: 1106)
ParamNBR: | 2 | | OK |
CalledNBR: | 45 | * | |
LOC: | 69 | | OK |
metrics are OK
gsd_box (Begins at: 1114 Ends at: 1175)
LOC: | 62 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-05-05 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 182 | 256 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
