[GRASS-QA] SOCCER LAB GRASS QA: no clones 1 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Sat May 6 03:27:38 EDT 2006
Hello cho,
ANALYSIS
vector/v.in.dxf/add_polyline.c functions
add_polyline (Begins at: 11 Ends at: 256)
Complexity: | 54 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 38 | * | |
LOC: | 246 | ** | Warning |
1 metric are OUT OF RANGE!
write_pnts (Begins at: 258 Ends at: 291)
Complexity: | 5 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 4 | | OK |
LOC: | 34 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-05-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
