[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca
Fri May 5 19:38:31 EDT 2006
Hello brad,
ANALYSIS
lib/image/row.c functions
putrow (Begins at: 13 Ends at: 136)
Complexity: | 32 | ** | Warning |
ParamNBR: | 4 | | OK |
CalledNBR: | 21 | | OK |
LOC: | 124 | * | |
at least 1 values are close to an outlier please consider revising code
getrow (Begins at: 138 Ends at: 216)
Complexity: | 22 | * | |
CalledNBR: | 14 | | OK |
LOC: | 79 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-05-05 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 182 | 256 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
