[GRASS-QA] SOCCER LAB GRASS QA: 2 clones ( gsd_fonts.c ) 0 monsters
	and 0 warnings
    cvs at proxy.soccerlab.polymtl.ca
    Fri May  5 19:38:31 EDT 2006
Hello brad,
ANALYSIS
lib/ogsf/gsd_fonts.c functions
gsd_get_txtwidth (Begins at: 26 Ends at: 34)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
gsd_get_txtheight (Begins at: 38 Ends at: 46)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
get_txtdescender (Begins at: 50 Ends at: 58)
ParamNBR:     |       0 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
get_txtxoffset (Begins at: 61 Ends at: 69)
LOC:          |       9 |       |      OK |
metrics are OK
do_label_display (Begins at: 72 Ends at: 79)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  get_txtxoffset  get_txtdescender
In lib/ogsf/gsd_fonts.c clones of  get_txtxoffset are:
	lib/ogsf/gsd_fonts.c  get_txtdescender
In lib/ogsf/gsd_fonts.c clones of  get_txtdescender are:
	lib/ogsf/gsd_fonts.c  get_txtxoffset
Threshold GRASS6 key metrics values at 2006-05-05 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
