[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Sat May 6 13:20:32 EDT 2006
Hello glynn,
ANALYSIS
general/g.pnmcomp/main.c functions
erase (Begins at: 13 Ends at: 31)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 19 | | OK |
metrics are OK
read_line (Begins at: 34 Ends at: 44)
Complexity: | 3 | | OK |
ParamNBR: | 3 | | OK |
LOC: | 11 | | OK |
metrics are OK
read_header (Begins at: 47 Ends at: 71)
Complexity: | 5 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 25 | | OK |
metrics are OK
read_pnm (Begins at: 74 Ends at: 158)
Complexity: | 20 | * | |
CalledNBR: | 15 | | OK |
LOC: | 85 | | OK |
metrics are OK
overlay (Begins at: 161 Ends at: 195)
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 35 | | OK |
metrics are OK
overlay_alpha (Begins at: 198 Ends at: 226)
LOC: | 29 | | OK |
metrics are OK
write_ppm (Begins at: 229 Ends at: 244)
CalledNBR: | 6 | | OK |
LOC: | 16 | | OK |
metrics are OK
main (Begins at: 247 Ends at: 349)
Complexity: | 7 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 103 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-05-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
