[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Sat May 6 18:56:22 EDT 2006
Hello soeren,
ANALYSIS
lib/g3d/g3dopen.c functions
G3d_openCellOldNoHeader (Begins at: 13 Ends at: 84)
Complexity: | 5 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 72 | | OK |
metrics are OK
G3d_openCellOld (Begins at: 87 Ends at: 214)
Complexity: | 14 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 34 | * | |
LOC: | 128 | * | |
metrics are OK
G3d_openCellNew (Begins at: 217 Ends at: 326)
Complexity: | 18 | * | |
ParamNBR: | 4 | | OK |
CalledNBR: | 31 | | OK |
LOC: | 110 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-05-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
