[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
    cvs at proxy.soccerlab.polymtl.ca
    Tue May 16 05:17:05 EDT 2006
Hello markus,
ANALYSIS
raster/r.timestamp/main.c functions
main (Begins at: 7 Ends at: 71)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      25 |       |      OK |
LOC:          |      65 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-16 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
