[GRASS-QA] SOCCER LAB GRASS QA: no clones 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue May 16 05:24:04 EDT 2006
Hello markus,
ANALYSIS
raster/r.info/main.c functions
main (Begins at: 35 Ends at: 442)
Complexity: | 57 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 197 | *** | MONSTER |
LOC: | 408 | *** | MONSTER |
3 metric are OUT OF RANGE!
format_double (Begins at: 445 Ends at: 451)
Complexity: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-05-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
