[GRASS-QA] SOCCER LAB GRASS QA: 1 clones ( parser.c ) 1 monsters
and 7 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue May 16 13:33:42 EDT 2006
Hello cedric,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 183 Ends at: 199)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_define_flag (Begins at: 202 Ends at: 250)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 49 | | OK |
metrics are OK
G_define_option (Begins at: 253 Ends at: 306)
LOC: | 54 | | OK |
metrics are OK
G_define_standard_option (Begins at: 309 Ends at: 431)
Complexity: | 16 | * | |
CalledNBR: | 16 | | OK |
LOC: | 123 | * | |
metrics are OK
G_define_module (Begins at: 434 Ends at: 468)
CalledNBR: | 1 | | OK |
LOC: | 35 | | OK |
metrics are OK
G_parser (Begins at: 470 Ends at: 705)
Complexity: | 34 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 56 | ** | Warning |
LOC: | 236 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 708 Ends at: 753)
Complexity: | 5 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 46 | | OK |
metrics are OK
G_usage (Begins at: 755 Ends at: 915)
Complexity: | 31 | ** | Warning |
CalledNBR: | 42 | * | |
LOC: | 161 | * | |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 917 Ends at: 933)
Complexity: | 6 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_usage_xml (Begins at: 935 Ends at: 1133)
Complexity: | 25 | * | |
CalledNBR: | 62 | ** | Warning |
LOC: | 199 | ** | Warning |
G_usage_html (Begins at: 1135 Ends at: 1352)
Complexity: | 40 | *** | MONSTER |
CalledNBR: | 71 | ** | Warning |
LOC: | 218 | ** | Warning |
1 metric are OUT OF RANGE!
generate_tcl (Begins at: 1354 Ends at: 1425)
Complexity: | 9 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 72 | | OK |
metrics are OK
G_gui (Begins at: 1428 Ends at: 1450)
CalledNBR: | 8 | | OK |
LOC: | 23 | | OK |
metrics are OK
G_tcltk (Begins at: 1453 Ends at: 1468)
LOC: | 16 | | OK |
metrics are OK
show_options (Begins at: 1470 Ends at: 1499)
Complexity: | 4 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 30 | | OK |
metrics are OK
show (Begins at: 1501 Ends at: 1514)
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
set_flag (Begins at: 1516 Ends at: 1543)
LOC: | 28 | | OK |
metrics are OK
contains (Begins at: 1548 Ends at: 1557)
LOC: | 10 | | OK |
metrics are OK
set_option (Begins at: 1559 Ends at: 1619)
CalledNBR: | 13 | | OK |
LOC: | 61 | | OK |
metrics are OK
check_opts (Begins at: 1621 Ends at: 1658)
LOC: | 38 | | OK |
metrics are OK
check_an_opt (Begins at: 1660 Ends at: 1702)
Complexity: | 10 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 43 | | OK |
metrics are OK
check_int (Begins at: 1704 Ends at: 1770)
Complexity: | 13 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 67 | | OK |
metrics are OK
check_double (Begins at: 1772 Ends at: 1812)
LOC: | 41 | | OK |
metrics are OK
check_string (Begins at: 1814 Ends at: 1841)
Complexity: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
check_required (Begins at: 1843 Ends at: 1866)
LOC: | 24 | | OK |
metrics are OK
split_opts (Begins at: 1868 Ends at: 1931)
LOC: | 64 | | OK |
metrics are OK
check_multiple_opts (Begins at: 1933 Ends at: 1971)
CalledNBR: | 5 | | OK |
LOC: | 39 | | OK |
metrics are OK
check_overwrite (Begins at: 1974 Ends at: 2030)
Complexity: | 11 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 57 | | OK |
metrics are OK
interactive (Begins at: 2032 Ends at: 2060)
LOC: | 29 | | OK |
metrics are OK
interactive_flag (Begins at: 2062 Ends at: 2070)
LOC: | 9 | | OK |
metrics are OK
interactive_option (Begins at: 2072 Ends at: 2162)
Complexity: | 23 | * | |
CalledNBR: | 41 | * | |
LOC: | 91 | | OK |
metrics are OK
split_gisprompt (Begins at: 2164 Ends at: 2194)
LOC: | 31 | | OK |
metrics are OK
gis_prompt (Begins at: 2196 Ends at: 2241)
CalledNBR: | 20 | | OK |
LOC: | 46 | | OK |
metrics are OK
G_recreate_command (Begins at: 2243 Ends at: 2343)
CalledNBR: | 25 | | OK |
LOC: | 101 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
interactive_flag
In lib/gis/parser.c clones of interactive_flag are:
lib/gis/rm_colr.c G_remove_colr
Threshold GRASS6 key metrics values at 2006-05-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
