[GRASS-QA] SOCCER LAB GRASS QA: no clones 1 monsters and 0 warnings
    cvs at proxy.soccerlab.polymtl.ca
    Mon May 22 09:50:41 EDT 2006
Hello markus,
ANALYSIS
vector/v.in.sites/main.c functions
main (Begins at: 30 Ends at: 236)
Complexity:   |      24 |     * |         |
CalledNBR:    |      96 |   *** | MONSTER |
LOC:          |     207 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-22 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
