[GRASS-QA] SOCCER LAB GRASS QA: no clones 1 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Mon May 22 09:39:33 EDT 2006
Hello markus,
ANALYSIS
vector/v.in.db/main.c functions
main (Begins at: 26 Ends at: 221)
Complexity: | 14 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 99 | *** | MONSTER |
LOC: | 196 | ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-05-22 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 182 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
