[GRASS-QA] GRASS QA: brad | ./grass6/lib/cdhc/as181.c |no clones |
2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Nov 3 23:17:01 EST 2006
Hello brad,
ANALYSIS
lib/cdhc/as181.c functions
wext (Begins at: 25 Ends at: 174)
Complexity: | 13 | | OK |
ParamNBR: | 9 | *** | MONSTER |
CalledNBR: | 25 | | OK |
LOC: | 150 | * | |
1 metric are OUT OF RANGE!
wcoef (Begins at: 182 Ends at: 265)
Complexity: | 9 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 8 | | OK |
LOC: | 84 | | OK |
metrics are OK
poly (Begins at: 267 Ends at: 298)
Complexity: | 3 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 32 | | OK |
metrics are OK
wgp (Begins at: 300 Ends at: 355)
Complexity: | 8 | | OK |
ParamNBR: | 12 | *** | MONSTER |
CalledNBR: | 5 | | OK |
LOC: | 56 | | OK |
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-11-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
