[GRASS-QA] GRASS QA: brad | ./grass6/lib/cdhc/as177.c |no clones |
0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Nov 3 23:17:01 EST 2006
Hello brad,
ANALYSIS
lib/cdhc/as177.c functions
nscor1 (Begins at: 27 Ends at: 62)
Complexity: | 4 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 4 | | OK |
LOC: | 36 | | OK |
metrics are OK
init (Begins at: 65 Ends at: 83)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
LOC: | 19 | | OK |
metrics are OK
alnfac (Begins at: 89 Ends at: 105)
Complexity: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 17 | | OK |
metrics are OK
nscor2 (Begins at: 111 Ends at: 164)
Complexity: | 6 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 54 | | OK |
metrics are OK
correc (Begins at: 171 Ends at: 194)
Complexity: | 5 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 24 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-11-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
