[GRASS-QA] GRASS QA: hamish | ./grass6/lib/imagery/list_subgp.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Nov 16 03:52:08 EST 2006
Hello hamish,
ANALYSIS
lib/imagery/list_subgp.c functions
I_list_subgroup (Begins at: 13 Ends at: 67)
Complexity: | 5 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 55 | | OK |
metrics are OK
I_list_subgroup_simple (Begins at: 69 Ends at: 72)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-11-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
