[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/rhumbline.c |no clones
| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Nov 16 03:52:08 EST 2006
Hello brad,
ANALYSIS
lib/gis/rhumbline.c functions
G_begin_rhumbline_equation (Begins at: 33 Ends at: 63)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 31 | | OK |
metrics are OK
G_rhumbline_lat_from_lon (Begins at: 67 Ends at: 86)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 20 | | OK |
metrics are OK
adjust_lat (Begins at: 88 Ends at: 94)
CalledNBR: | 0 | | OK |
LOC: | 7 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-11-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
