[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.watershed/front/main.c |no clones | 2 monsters | 0 warnings
Fri Nov 17 03:58:37 EST 2006
Hello hamish,
ANALYSIS
raster/r.watershed/front/main.c functions
main (Begins at: 9 Ends at: 341)
Complexity:   |      29 |    ** | Warning |
CalledNBR:    |     134 |   *** | MONSTER |
LOC:          |     333 |   *** | MONSTER |
2 metric are OUT OF RANGE!
write_hist (Begins at: 344 Ends at: 358)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-17 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
