[GRASS-QA] GRASS QA: glynn | ./grass6/lib/stats/c_percentile.c |1 clones ( c_ave.c c_count.c c_mode.c c_percentile.c )| 0 monsters | 0 warnings
Mon Oct 2 19:00:24 EDT 2006
Hello glynn,
ANALYSIS
lib/stats/c_percentile.c functions
percentile (Begins at: 5 Ends at: 25)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
c_quart1 (Begins at: 27 Ends at: 30)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
c_quart3 (Begins at: 32 Ends at: 35)
LOC:          |       4 |       |      OK |
metrics are OK
c_perc90 (Begins at: 37 Ends at: 40)
LOC:          |       4 |       |      OK |
metrics are OK
percentile_w (Begins at: 42 Ends at: 69)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
w_quart1 (Begins at: 71 Ends at: 74)
LOC:          |       4 |       |      OK |
metrics are OK
w_quart3 (Begins at: 76 Ends at: 79)
LOC:          |       4 |       |      OK |
metrics are OK
w_perc90 (Begins at: 81 Ends at: 84)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  percentile
In lib/stats/c_percentile.c clones of  percentile are:
	raster/r.series/c_percentile.c  percentile
Threshold GRASS6 key metrics values at 2006-10-02 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      81 |
LOC:                    40 |       182 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
