[GRASS-QA] GRASS QA: glynn | ./grass6/lib/stats/c_mode.c |1 clones
( c_ave.c c_count.c c_mode.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Oct 2 19:00:24 EDT 2006
Hello glynn,
ANALYSIS
lib/stats/c_mode.c functions
c_mode (Begins at: 4 Ends at: 38)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 35 | | OK |
metrics are OK
w_mode (Begins at: 40 Ends at: 74)
LOC: | 35 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
c_mode
In lib/stats/c_mode.c clones of c_mode are:
raster/r.series/c_mode.c c_mode
Threshold GRASS6 key metrics values at 2006-10-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 81 |
LOC: 40 | 182 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
