[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.resamp.stats/main.c
|1 clones ( c_ave.c c_count.c c_mode.c c_percentile.c c_reg.c
c_stddev.c c_sum.c c_var.c sort_cell.c main.c )| 0 monsters |
0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Oct 2 19:00:24 EDT 2006
Hello glynn,
ANALYSIS
raster/r.resamp.stats/main.c functions
build_method_list (Begins at: 27 Ends at: 44)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 18 | | OK |
metrics are OK
find_method (Begins at: 46 Ends at: 55)
LOC: | 10 | | OK |
metrics are OK
resamp_unweighted (Begins at: 65 Ends at: 137)
Complexity: | 3 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 73 | | OK |
metrics are OK
resamp_weighted (Begins at: 139 Ends at: 228)
CalledNBR: | 20 | | OK |
LOC: | 90 | | OK |
metrics are OK
main (Begins at: 230 Ends at: 346)
Complexity: | 7 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 54 | * | |
LOC: | 117 | * | |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
build_method_list
In raster/r.resamp.stats/main.c clones of build_method_list are:
raster/r.series/main.c build_method_list
Threshold GRASS6 key metrics values at 2006-10-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 81 |
LOC: 40 | 182 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
