[GRASS-QA] GRASS QA: brad | ./grass6/lib/db/dbmi_base/dirent.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Oct 11 05:10:38 EDT 2006
Hello brad,
ANALYSIS
lib/db/dbmi_base/dirent.c functions
db_dirent (Begins at: 35 Ends at: 98)
Complexity: | 8 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 19 | | OK |
LOC: | 64 | | OK |
metrics are OK
db_free_dirent_array (Begins at: 107 Ends at: 118)
Complexity: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 12 | | OK |
metrics are OK
get_perm (Begins at: 121 Ends at: 136)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 16 | | OK |
metrics are OK
cmp_dirent (Begins at: 139 Ends at: 145)
Complexity: | 1 | | OK |
LOC: | 7 | | OK |
metrics are OK
sort_dirent (Begins at: 148 Ends at: 152)
CalledNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
db_alloc_dirent_array (Begins at: 161 Ends at: 175)
LOC: | 15 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
