[GRASS-QA] GRASS QA: brad | ./grass6/lib/db/dbmi_base/index.c |no clones | 0 monsters | 0 warnings
Wed Oct 11 05:10:38 EDT 2006
Hello brad,
ANALYSIS
lib/db/dbmi_base/index.c functions
db_init_index (Begins at: 12 Ends at: 20)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
db_free_index (Begins at: 29 Ends at: 37)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
db_alloc_index_columns (Begins at: 46 Ends at: 55)
LOC:          |      10 |       |      OK |
metrics are OK
db_alloc_index_array (Begins at: 64 Ends at: 77)
LOC:          |      14 |       |      OK |
metrics are OK
db_free_index_array (Begins at: 86 Ends at: 97)
LOC:          |      12 |       |      OK |
metrics are OK
db_set_index_name (Begins at: 106 Ends at: 110)
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
db_get_index_name (Begins at: 119 Ends at: 123)
LOC:          |       5 |       |      OK |
metrics are OK
db_set_index_table_name (Begins at: 132 Ends at: 136)
LOC:          |       5 |       |      OK |
metrics are OK
db_get_index_table_name (Begins at: 145 Ends at: 149)
LOC:          |       5 |       |      OK |
metrics are OK
db_get_index_number_of_columns (Begins at: 158 Ends at: 162)
CalledNBR:    |       0 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
db_set_index_column_name (Begins at: 171 Ends at: 180)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
db_get_index_column_name (Begins at: 189 Ends at: 198)
LOC:          |      10 |       |      OK |
metrics are OK
db_set_index_type_unique (Begins at: 207 Ends at: 212)
LOC:          |       6 |       |      OK |
metrics are OK
db_set_index_type_non_unique (Begins at: 221 Ends at: 226)
LOC:          |       6 |       |      OK |
metrics are OK
db_test_index_type_unique (Begins at: 235 Ends at: 238)
LOC:          |       4 |       |      OK |
metrics are OK
db_print_index (Begins at: 247 Ends at: 263)
CalledNBR:    |      11 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
