[GRASS-QA] GRASS QA: brad | ./grass6/lib/db/dbmi_base/sqlCtype.c |no clones | 0 monsters | 0 warnings
Wed Oct 11 05:10:38 EDT 2006
Hello brad,
ANALYSIS
lib/db/dbmi_base/sqlCtype.c functions
db_sqltype_to_Ctype (Begins at: 10 Ends at: 30)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
