[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.le/r.le.setup/sample.c |no clones | 10 monsters | 2 warnings
Wed Oct 11 05:10:43 EDT 2006
Hello markus,
ANALYSIS
raster/r.le/r.le.setup/sample.c functions
sample (Begins at: 51 Ends at: 115)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      16 |       |      OK |
LOC:          |      65 |       |      OK |
at least 1 values are close to an outlier please consider revising code
man_unit (Begins at: 121 Ends at: 652)
Complexity:   |      57 |   *** | MONSTER |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |     157 |   *** | MONSTER |
LOC:          |     532 |   *** | MONSTER |
4 metric are OUT OF RANGE!
draw_grid (Begins at: 657 Ends at: 718)
Complexity:   |       3 |       |      OK |
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |       8 |       |      OK |
LOC:          |      62 |       |      OK |
1 metric are OUT OF RANGE!
calc_unit_loc (Begins at: 723 Ends at: 959)
Complexity:   |      28 |    ** | Warning |
ParamNBR:     |      22 |   *** | MONSTER |
CalledNBR:    |      44 |     * |         |
LOC:          |     237 |    ** | Warning |
get_rd (Begins at: 964 Ends at: 976)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      13 |       |      OK |
f (Begins at: 981 Ends at: 986)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
overlap (Begins at: 991 Ends at: 997)
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
calc_num (Begins at: 1002 Ends at: 1028)
Complexity:   |       4 |       |      OK |
ParamNBR:     |      11 |   *** | MONSTER |
CalledNBR:    |       4 |       |      OK |
LOC:          |      27 |       |      OK |
graph_unit (Begins at: 1036 Ends at: 1431)
Complexity:   |      35 |    ** | Warning |
CalledNBR:    |     117 |   *** | MONSTER |
LOC:          |     396 |   *** | MONSTER |
3 metric are OUT OF RANGE!
draw_box (Begins at: 1436 Ends at: 1465)
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      11 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
draw_circle (Begins at: 1470 Ends at: 1510)
CalledNBR:    |       7 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
numtrap (Begins at: 1515 Ends at: 1583)
Complexity:   |      10 |       |      OK |
LOC:          |      69 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
