[GRASS-QA] GRASS QA: brad | ./grass6/lib/db/dbmi_base/xdrcolumn.c
|2 clones ( xdrchar.c xdrcolumn.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Oct 11 05:10:38 EDT 2006
Hello brad,
ANALYSIS
lib/db/dbmi_base/xdrcolumn.c functions
db__send_column_definition (Begins at: 6 Ends at: 26)
Complexity: | 15 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 26 | | OK |
LOC: | 21 | | OK |
metrics are OK
db__recv_column_definition (Begins at: 29 Ends at: 49)
LOC: | 21 | | OK |
metrics are OK
db__send_column_value (Begins at: 53 Ends at: 57)
Complexity: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 5 | | OK |
metrics are OK
db__recv_column_value (Begins at: 61 Ends at: 65)
LOC: | 5 | | OK |
metrics are OK
db__send_column_default_value (Begins at: 68 Ends at: 72)
LOC: | 5 | | OK |
metrics are OK
db__recv_column_default_value (Begins at: 75 Ends at: 79)
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
db__recv_column_definition db__send_column_definition
In lib/db/dbmi_base/xdrcolumn.c clones of db__recv_column_definition are:
lib/db/dbmi_base/xdrcolumn.c db__send_column_definition
In lib/db/dbmi_base/xdrcolumn.c clones of db__send_column_definition are:
lib/db/dbmi_base/xdrcolumn.c db__recv_column_definition
Threshold GRASS6 key metrics values at 2006-10-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
