[GRASS-QA] GRASS QA: brad | ./grass6/lib/db/dbmi_base/xdrdatetime.c
|2 clones ( xdrchar.c xdrcolumn.c xdrdatetime.c )| 0 monsters
| 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Oct 11 05:10:38 EDT 2006
Hello brad,
ANALYSIS
lib/db/dbmi_base/xdrdatetime.c functions
db__send_datetime (Begins at: 6 Ends at: 20)
Complexity: | 9 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 15 | | OK |
metrics are OK
db__recv_datetime (Begins at: 23 Ends at: 37)
LOC: | 15 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
db__recv_datetime db__send_datetime
In lib/db/dbmi_base/xdrdatetime.c clones of db__send_datetime are:
lib/db/dbmi_base/xdrdatetime.c db__recv_datetime
In lib/db/dbmi_base/xdrdatetime.c clones of db__recv_datetime are:
lib/db/dbmi_base/xdrdatetime.c db__send_datetime
Threshold GRASS6 key metrics values at 2006-10-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
