[GRASS-QA] GRASS QA: brad | ./grass6/lib/db/dbmi_base/xdrdouble.c |1 clones ( xdrchar.c xdrcolumn.c xdrdatetime.c xdrdouble.c )| 0 monsters | 0 warnings
Wed Oct 11 05:10:38 EDT 2006
Hello brad,
ANALYSIS
lib/db/dbmi_base/xdrdouble.c functions
db__send_double (Begins at: 6 Ends at: 23)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
db__recv_double (Begins at: 26 Ends at: 41)
LOC:          |      16 |       |      OK |
metrics are OK
db__send_double_array (Begins at: 45 Ends at: 71)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
db__recv_double_array (Begins at: 76 Ends at: 124)
Complexity:   |      10 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  db__recv_double
In lib/db/dbmi_base/xdrdouble.c clones of  db__recv_double are:
	lib/db/dbmi_base/xdrfloat.c  db__send_float
	lib/db/dbmi_base/xdrint.c  db__send_int
	lib/db/dbmi_base/xdrchar.c  db__recv_char
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
