[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.le/r.le.patch/driver.c |no clones | 6 monsters | 1 warnings
Wed Oct 11 05:10:41 EDT 2006
Hello hamish,
ANALYSIS
raster/r.le/r.le.patch/driver.c functions
patch_fore (Begins at: 66 Ends at: 127)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |      22 |       |      OK |
LOC:          |      62 |       |      OK |
metrics are OK
open_files (Begins at: 135 Ends at: 416)
Complexity:   |      31 |    ** | Warning |
CalledNBR:    |     160 |   *** | MONSTER |
LOC:          |     282 |   *** | MONSTER |
2 metric are OUT OF RANGE!
fopen0 (Begins at: 423 Ends at: 437)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
fopen1 (Begins at: 443 Ends at: 460)
CalledNBR:    |      10 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
fopen2 (Begins at: 465 Ends at: 481)
CalledNBR:    |       9 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
mv_driver (Begins at: 487 Ends at: 2186)
Complexity:   |     347 |   *** | MONSTER |
CalledNBR:    |     761 |   *** | MONSTER |
LOC:          |    1700 |   *** | MONSTER |
3 metric are OUT OF RANGE!
set_colors (Begins at: 2188 Ends at: 2199)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
read_mwind (Begins at: 2207 Ends at: 2235)
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      12 |       |      OK |
LOC:          |      29 |       |      OK |
at least 1 values are close to an outlier please consider revising code
meter (Begins at: 2243 Ends at: 2281)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
get_para (Begins at: 2286 Ends at: 2382)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      97 |       |      OK |
metrics are OK
free_para (Begins at: 2384 Ends at: 2412)
LOC:          |      29 |       |      OK |
metrics are OK
read_para (Begins at: 2414 Ends at: 2483)
ParamNBR:     |       4 |       |      OK |
LOC:          |      70 |       |      OK |
metrics are OK
read_line (Begins at: 2491 Ends at: 2535)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       6 |     * |         |
LOC:          |      45 |       |      OK |
metrics are OK
unit_driver (Begins at: 2537 Ends at: 2666)
Complexity:   |      22 |     * |         |
CalledNBR:    |      49 |     * |         |
LOC:          |     130 |     * |         |
metrics are OK
run_clip (Begins at: 2668 Ends at: 2716)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       9 |   *** | MONSTER |
LOC:          |      49 |       |      OK |
1 metric are OUT OF RANGE!
whole_reg_driver (Begins at: 2723 Ends at: 2797)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      75 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
