[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.null/null.c |1
clones ( xdrchar.c xdrcolumn.c xdrdatetime.c xdrdouble.c
xdrint.c xdrshort.c xdrstring.c create_map.c null.c null.c
null.c )| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Oct 11 05:10:41 EDT 2006
Hello glynn,
ANALYSIS
raster/r.null/null.c functions
main (Begins at: 15 Ends at: 186)
Complexity: | 16 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 63 | ** | Warning |
LOC: | 172 | * | |
at least 1 values are close to an outlier please consider revising code
parse_vallist (Begins at: 188 Ends at: 221)
Complexity: | 6 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 34 | | OK |
metrics are OK
parse_d_mask_rule (Begins at: 224 Ends at: 253)
ParamNBR: | 3 | | OK |
LOC: | 30 | | OK |
metrics are OK
process (Begins at: 256 Ends at: 298)
Complexity: | 7 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 43 | | OK |
metrics are OK
doit (Begins at: 301 Ends at: 349)
CalledNBR: | 18 | | OK |
LOC: | 49 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
parse_vallist
In raster/r.null/null.c clones of parse_vallist are:
display/d.rast/main.c parse_vallist
display/d.rast/main.c parse_catlist
Threshold GRASS6 key metrics values at 2006-10-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
