[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.null/null.c |1
	clones ( xdrchar.c xdrcolumn.c xdrdatetime.c xdrdouble.c
	xdrint.c xdrshort.c xdrstring.c create_map.c null.c null.c
	null.c null.c )| 0 monsters | 1 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Wed Oct 11 05:10:43 EDT 2006
Hello markus,
ANALYSIS
raster/r.null/null.c functions
main (Begins at: 15 Ends at: 186)
Complexity:   |      16 |     * |         |
CalledNBR:    |      63 |    ** | Warning |
LOC:          |     172 |     * |         |
at least 1 values are close to an outlier please consider revising code
parse_vallist (Begins at: 188 Ends at: 221)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
parse_d_mask_rule (Begins at: 224 Ends at: 253)
ParamNBR:     |       3 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
process (Begins at: 256 Ends at: 298)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
doit (Begins at: 301 Ends at: 349)
CalledNBR:    |      18 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  parse_vallist
In raster/r.null/null.c clones of  parse_vallist are:
	display/d.rast/main.c  parse_vallist
	display/d.rast/main.c  parse_catlist
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
