[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.resamp.stats/main.c
|1 clones ( parser.c main.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Oct 11 05:38:41 EDT 2006
Hello glynn,
ANALYSIS
raster/r.resamp.stats/main.c functions
build_method_list (Begins at: 28 Ends at: 45)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 18 | | OK |
metrics are OK
find_method (Begins at: 47 Ends at: 56)
LOC: | 10 | | OK |
metrics are OK
resamp_unweighted (Begins at: 66 Ends at: 138)
Complexity: | 3 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 73 | | OK |
metrics are OK
resamp_weighted (Begins at: 140 Ends at: 229)
CalledNBR: | 20 | | OK |
LOC: | 90 | | OK |
metrics are OK
main (Begins at: 231 Ends at: 347)
Complexity: | 7 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 54 | * | |
LOC: | 117 | * | |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
build_method_list
In raster/r.resamp.stats/main.c clones of build_method_list are:
raster/r.series/main.c build_method_list
Threshold GRASS6 key metrics values at 2006-10-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
