[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/parser.c |1 clones (
	parser.c )| 1 monsters | 7 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Wed Oct 11 05:38:40 EDT 2006
Hello glynn,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 200 Ends at: 216)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_define_flag (Begins at: 219 Ends at: 267)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
G_define_option (Begins at: 270 Ends at: 340)
LOC:          |      71 |       |      OK |
metrics are OK
G_define_standard_option (Begins at: 343 Ends at: 520)
Complexity:   |      22 |     * |         |
CalledNBR:    |      22 |       |      OK |
LOC:          |     178 |     * |         |
metrics are OK
G_define_module (Begins at: 523 Ends at: 557)
CalledNBR:    |       1 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
G_parser (Begins at: 559 Ends at: 820)
Complexity:   |      36 |   *** | MONSTER |
CalledNBR:    |      70 |    ** | Warning |
LOC:          |     262 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 823 Ends at: 868)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
G_usage (Begins at: 870 Ends at: 1044)
Complexity:   |      32 |    ** | Warning |
CalledNBR:    |      53 |     * |         |
LOC:          |     175 |     * |         |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1046 Ends at: 1062)
Complexity:   |       6 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_usage_xml (Begins at: 1064 Ends at: 1268)
Complexity:   |      26 |    ** | Warning |
CalledNBR:    |      65 |    ** | Warning |
LOC:          |     205 |    ** | Warning |
G_usage_html (Begins at: 1270 Ends at: 1501)
Complexity:   |      41 |   *** | MONSTER |
CalledNBR:    |      80 |    ** | Warning |
LOC:          |     232 |    ** | Warning |
1 metric are OUT OF RANGE!
generate_tcl (Begins at: 1503 Ends at: 1588)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      33 |       |      OK |
LOC:          |      86 |       |      OK |
metrics are OK
G_gui (Begins at: 1591 Ends at: 1620)
CalledNBR:    |       8 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
G_tcltk (Begins at: 1623 Ends at: 1638)
LOC:          |      16 |       |      OK |
metrics are OK
show_options (Begins at: 1640 Ends at: 1669)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
show (Begins at: 1671 Ends at: 1684)
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
set_flag (Begins at: 1686 Ends at: 1713)
LOC:          |      28 |       |      OK |
metrics are OK
contains (Begins at: 1718 Ends at: 1727)
LOC:          |      10 |       |      OK |
metrics are OK
set_option (Begins at: 1729 Ends at: 1789)
CalledNBR:    |      13 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
check_opts (Begins at: 1791 Ends at: 1828)
LOC:          |      38 |       |      OK |
metrics are OK
check_an_opt (Begins at: 1830 Ends at: 1872)
ParamNBR:     |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
check_int (Begins at: 1874 Ends at: 1940)
Complexity:   |      13 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
check_double (Begins at: 1942 Ends at: 1982)
LOC:          |      41 |       |      OK |
metrics are OK
check_string (Begins at: 1984 Ends at: 2011)
Complexity:   |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
check_required (Begins at: 2013 Ends at: 2036)
LOC:          |      24 |       |      OK |
metrics are OK
split_opts (Begins at: 2038 Ends at: 2101)
LOC:          |      64 |       |      OK |
metrics are OK
check_multiple_opts (Begins at: 2103 Ends at: 2141)
CalledNBR:    |       5 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
check_overwrite (Begins at: 2144 Ends at: 2200)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
interactive (Begins at: 2202 Ends at: 2230)
LOC:          |      29 |       |      OK |
metrics are OK
interactive_flag (Begins at: 2232 Ends at: 2240)
LOC:          |       9 |       |      OK |
metrics are OK
interactive_option (Begins at: 2242 Ends at: 2332)
Complexity:   |      23 |     * |         |
CalledNBR:    |      41 |     * |         |
LOC:          |      91 |       |      OK |
metrics are OK
split_gisprompt (Begins at: 2334 Ends at: 2364)
LOC:          |      31 |       |      OK |
metrics are OK
gis_prompt (Begins at: 2366 Ends at: 2411)
CalledNBR:    |      20 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
G_recreate_command (Begins at: 2413 Ends at: 2515)
CalledNBR:    |      25 |       |      OK |
LOC:          |     103 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  interactive_flag
In lib/gis/parser.c clones of  interactive_flag are:
	lib/gis/rm_colr.c  G_remove_colr
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
