[GRASS-QA] GRASS QA: moritz | ./grass6/db/drivers/dbf/dbfexe.c |no
clones | 3 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Oct 11 05:38:42 EDT 2006
Hello moritz,
ANALYSIS
db/drivers/dbf/dbfexe.c functions
execute (Begins at: 42 Ends at: 297)
Complexity: | 29 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 50 | * | |
LOC: | 256 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
get_col_def (Begins at: 300 Ends at: 324)
Complexity: | 6 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 0 | | OK |
LOC: | 25 | | OK |
metrics are OK
eval_val (Begins at: 326 Ends at: 384)
Complexity: | 10 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 59 | | OK |
metrics are OK
set_val (Begins at: 386 Ends at: 435)
Complexity: | 9 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 50 | | OK |
metrics are OK
cmp_row_asc (Begins at: 440 Ends at: 473)
CalledNBR: | 1 | | OK |
LOC: | 34 | | OK |
metrics are OK
cmp_row_desc (Begins at: 475 Ends at: 480)
Complexity: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
sel (Begins at: 484 Ends at: 598)
Complexity: | 15 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 21 | | OK |
LOC: | 115 | | OK |
metrics are OK
eval_node (Begins at: 600 Ends at: 911)
Complexity: | 72 | *** | MONSTER |
CalledNBR: | 17 | | OK |
LOC: | 312 | *** | MONSTER |
2 metric are OUT OF RANGE!
eval_node_type (Begins at: 913 Ends at: 1048)
Complexity: | 44 | *** | MONSTER |
LOC: | 136 | * | |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
