[GRASS-QA] GRASS QA: moritz | ./grass6/lib/db/sqlp/print.c |no
	clones | 0 monsters | 1 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Wed Oct 11 05:38:42 EDT 2006
Hello moritz,
ANALYSIS
lib/db/sqlp/print.c functions
print_node (Begins at: 24 Ends at: 58)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
sqpPrintStmt (Begins at: 60 Ends at: 174)
Complexity:   |      27 |    ** | Warning |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      33 |       |      OK |
LOC:          |     115 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
