[GRASS-QA] GRASS QA: brad | ./grass6/lib/imagery/ls_groups.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Oct 12 05:02:57 EDT 2006
Hello brad,
ANALYSIS
lib/imagery/ls_groups.c functions
I_list_groups (Begins at: 13 Ends at: 77)
Complexity: | 10 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 33 | | OK |
LOC: | 65 | | OK |
metrics are OK
I_list_subgroups (Begins at: 79 Ends at: 136)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 30 | | OK |
LOC: | 58 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
